Hello,
I am here a bit more than just desperate. The point is that, it is being almost 5 months since I had the chance to finish the assembly of my completly new LS7 motor (new block, new rotating assembly, TSP LS7 265cc heads, SLP headers, LS7 lifters, Vararam, 11.7 SCR, etc.), which was installed into my 01 C5Z. The car already has 700 miles in the odo, and as you would imagine I have been working with street tune up of the PCM, using HPT.
The PROBLEM, KR by 2,400 rpm till 4,800 rpm (sometimes even further). And let me tell you that I have more than clear the point that I have to adjust the setting of the KR sensors, which as you would imagine, I have...Nevertheless, the situation is present, and the level of frustrationg is getting high
I have played endlessly with calibration, parting from Knock sensor level in Tip in, RPM, as well as with Global Gain.
Would you mind to take a look into my HPT files, and suggest me a fix? Is going to be appreciated big time.
FYI, the car is using NGK TR6 (colder plugs), here in Mexico City we have 92 octane gasoline, Racetronix fuel pump as well as the harness upgrade. The fuel injectors are the LS7. The Knock sensors are new and were installed by modding the block (different bolt pattern), the puter is the one that came with the car, as I used a 24X reluctor ring, as well as 1X cam sprocket. BTW, the Knock sensor?s harness is Katech, and bought new.
Thanks in advance.
Rodolfo LPC5 Z06 with 427ciLS7 Lingen timing 03 noviembre 2016.hpt04 diciembre 2016 19 02 horas.hpl
