92 gmc 99 ls1 swapped 799 heads and a btr stage 2 na cam.
truck was missing and running terrible after I replaced a pushrod I bent and swapped to flex fuel injectors from a 2004 5.3 and put an ls6 intake on it then I found that the lifter was destroyed so I pulled the heads and put new cam (did not degree it in just straight up) lifters valve springs and a set of 799 heads on it. no longer has any miss but it runs terribly rich and the o2 sensors set at 0 like it is very lean. idles with about 14" of vacuum but have had the intake back on and off and sprayed all around it with brake clean looking for a vacuum leak but it does not have one. on a cold start up it will idle forever but if you touch the throttle it will not idle again until pretty much the next day or it cools all the way off. also the fuel trims slowly climb all the way up and set there at 25 and 56 sometimes they will reset them selfs and it will idle a little better but not always. im super new to this and have no idea where to go from here
here is the tune and a log
thanks in advance for any help.
jeff
