I have installed a 99 Camaro engine/trans into my BMW and have been running it for about 2 years. Recently bought and installed a wideband controller and installed the output to C1 Blue pin 55. The scanner is set up correctly to receive the input, but it does not read any voltage. EGR is enabled in the tune. If I connect it to pin C of the ac pressure sensor [goes to C2 (red) pin 14] it works perfectly. I have ac in the car, and rather not have a switch to toggle between the two. Is there an other settings to change in the tune for it to read through egr. Its a standard OS. I will upload the tune file tonight.
Much appreciated
