Results 1 to 8 of 8
Thread: Detect Protocol Failed
    How long does it normally take you hear from technical support? I am having an issue with a Detect Protocol Failed error code and have sent everything asked for from them. Three days later nothing? any ideas?
    So I guess I will provide more info. I am trying to pull my tune off of my 2006 Chevy Cobalt ss. when I try to connect to the car it gives me said error. think it was the cable or caused by the update I connected my laptop to my wife's car a 2013 Chevy Cruze with out issue. and then my brothers 2007 Chevy truck again with out issue. I have trouble shooted the terminal and other more basic obd2 scanners will connect to the car but not my hpt???
    any ideas would be helpful
    Tuner in Training boostbuick's Avatar
    Jan 2017
    36
    I belive that u need to make shure the sigerette lighter fuse is good and not blown and need to make shure u have points for the tuner to use on that car unless u do not have the latest software update for that year check that. and let me know what u do when u plug in to the obd2 port if it fails it dosnt detect any signal because of the fuse runs the port also ,let me know ttyl boostbuick
    Jan 2017
    15
    I have same problem but finally got it to read about half the tune then a window popped up saying send some info to hptuners support. Now I guess I sit and wait. Not impressed so far. Trying to read a 2017 Z06. $650, and this. Geeze
    Nov 2009
    32
    Not the same issue. 2017's need to be unlocked. Read the instructions in the gen5 forum.
    Jan 2017
    15
    Yeah, I sent the info file. Also looks like the 8 speed is not supported. Lots of stuff in the fine print. Oh well, live and learn I guess.
    Tuner JHPerformance's Avatar
    Jan 2014
    Central KY
    95
    Quote Originally Posted by william.davis84 View Post
    Check your OBDII port power, if your interface works fine on other vehicles something with the cobalt isn't jiving. Make sure there are no aftermarket electronics causing an interference with your interface. Things such as aftermarket radios(common) ballast controlled lights, amps, even had a rust control box wired into a chevy truck once, hidden and never found it... lol I doubt yours has that but check your basics first.
    Jake Hatfield
    Central KY
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    Quote Originally Posted by dwiall View Post
    Its supported as detailed here http://www.hptuners.com/forum/showth...ison-Supported!
