Hey guys, need some guidance/suggestions.
LS1 with manual T56. No MAF.
I think I did all the correct settings for speed density idle tuning.
I did a log from cold start for 30mins. I also had "reset fuel trims" in the VCM controls prior to start up. My trims seemed weird as they were sometimes both + and - at the same time, after the 30 mins they were not to far off 0. Should I log longer to get a true sense of where they will finally settle?
Also my AFR is around 13.0. How do I go about getting it to idle closer to stoich? I assume adjust the primary VE table in the cell area where it idles for that rpm and kpa. When logging my "Air fuel ratio error" was actually logging and showing feedback but for some reason when I playback the saved log its not showing.
Any guidance on changes for my idle AFR would be great. and advise regarding my trims.
I hope I gave enough description/explanation. Let me know if I need to provide more.
Thanks.
Nov. 23 - 30min idle.hpl
AFR3.cfg
nov11 - timing4.hpt
