Hello, I have rebuilt my 2001 5.3 Tahoe engine and it is now a 5.7. I have changed the motor size, the cylinder volume and (tried) to shut-off all TCC on Engine and Transmission tables. January will have it sportin' twin turbos but for now I want it running as well as it possibly can be running with stock every-thing, except 53" BFG T/A's all 'round. I MEAN 33" BFG's oops!!! (lowered to 28psi for winter shenanegins)
It starts-idles-runs and transitions very well but, like someone else mentioned on this site; there is NO low-end torque? I know I do have to check my fuel pressure, but everything seems fine...Plugged-up cats? When I put her in 2-wheel Drive and lightly hold the brakes, I can NOT for the life of me get any wheel spin unless I'm on wet leaves or mud? On my front lawn you can feel the passenger wheel slip a bit for just a second before the G80 diff locks-up and brings the drivers' side wheel into action,(cool beans I didn't even know I had a posi 'till now!) On pavement, however, the tachometer only shows 1800-1900 rpm's and that is it! I cannot get it above 2000 rpm no matter what I do. (I lowered PE to 0 sec and 0 rpm.) Is that normal with these trucks? The engine sounds healthy; no knock or rattle, but no balls either? If I break-it-loose rounding a corner it sounds wicked, strong, and powerful. It'll do over 100 km/hr in no time and runs great with the egr shut-off with a LS1 plate.
When the motor was being rebuilt/re-bored I rented a Ram Sportsman 1500 with the 5.7 hemi and it brake-torqued like crazy, even though I hated every single thing about that Truck; the stupid shifter, the 'dead' feel electronic steering, the non-connected throttle, I HATED that truck for all it was worth and if you floored it fast from a stop it would read TPS fault (I kid you not!), it would stumble and fidget looking for 500* of timing or whatever but it still brake-torqued!
Will someone please give this tune a look over and I will buy you a beer or an AFR or something...
Primo Pre-Turbo Tune by Jef Tek.hptneighhborhood.hpl
I hope I attached these right and THANKS,
-jef
