2005 lq9 Custom Cam (228/230 .585/.585 112), Upgraded Dual Valve Spring Kit, Upgraded Bronze Trunion Rockers, Hardened Push Rods, Upgraded Pistons, Rings and Bearings, New LS7 Lifters, Upgraded High Pressure Oil Pump, Upgraded Billet Timing Chain and Dampener, Complete Gasket Kit, (Iron Block with Aluminum Cylinder Heads - 24x Timing Setup)
*Vortec Accessory Package: Alternator, Power Steering, Water Pump and Belt Tensioner, Oil Pan, Intake Manifold with DBC Throttle Body, Fuel Rails with EV6 Flex Fuel 33# Injectors, Starter and Crank Pulley. Also includes Ignition Coil Packs with Bracket and Subharnesses, MAP Sensor, Coolant Sensors, Knock Sensors and Subharness, Oil Pressure Sensor, Oil Level Sensor, Crank Sensor, Cam Sensor, Serpentine Belt, Spark Plugs and Wires *Universal 255 In-Tank Fuel Pump
2005 2500HD 4X4 4:10 REAREND 4L80E
CAM SPECS. 228/230 .585/.585 112
HEADERS
THROTTLE BODY UPGRADE
Please help I erased my original tune and need help getting my truck to run, I tried a base tune and it wont run right???? please help!!
