Been seeing the 15+ mustangs commanded EQ does not match the actual A\F as commanded in wot fuel table, Whats going on here. looked at several other data logs posted by others and they all do the same, actual not matching commanded EQ.
post your datalog and file
Car has JLT and borla lt headers no cats
if you are referring to the commanded eq your are logging not matching yes it never really matches. as long as wot lambda matches wot target you are good to go
your maf is about 10-15% happy . trim the whole thing by 10% . your load is 110-116% and your over 101kpa . you may want to adjust either the spark or vct to get rid of the knock also. a good start would be to change the added base advance of "2" to 0 since your borderline is already 21 .
I found some differences between the cars WB sensors and both an Autronic and Dyno WB sensors, I found raising the bias at high load high rpm to the Max 0.015 rectified this such that the targets matched the actuals in both the car and to an external sensor.
Are you saying a closed loop bias table affects an open loop fuel source condition? Or am I thinking of the wrong tables?
