Results 1 to 6 of 6
Thread: changes in cylinder airmass with timing advance
    Jan 2012
    29
    I added some timing to my tune, seems to run really well but my cylinder airmass measurements dropped across the board. At 6400 ish my airmass used to be around .82 g now its topping out at .71g . Does this mean the increased timing decreased power? I was trying to use the delivered torque pid to gauge effectiveness of changes and it is directly proportionate to airmass i think.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Change it back and see what happens..
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Jan 2012
    29
    I had planned to do that but was just wondering if that drop in airmass reflected a loss in power
    Mar 2010
    Texas Hill Country
    3,299
    your scanner is not a dyno.
    Tuning Addict
    Jan 2015
    6,802
    From what I see for whatever reason - it may go up or it may go down with more hp and tq, so like Higgs said - your scanner isn't a dyno If it's running better and you possibly have some sort of way to measure acceleration and it got better too then you've probably gone in the right direction...
    ~Greg Huggins~
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    Not sure what you mean by airmass "topping out" but if you now run the same performance level (throttle vs rpm vs speed) with less airmass, then your drop in airmass is a good thing.
    Regardless, as others said, it's not a dyno....
    2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
    Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
    Nitto NT05R 305x19, 255x18 on CCW T10s
    Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
