I know there are a few people having issue with these, myself included. I have tuned a couple but am not toatally happy with the results and have a couple of queries for other who may have been tuning these for longer as they are relatively new to Australia and are totally different to the Australian vehicles.
Firstly are people using HP able to acheive driveability similar to stock? I have issues with torque throttle corrections at low rpm medium load transitions, particularly when driving up a gradual incline or accelerating from a set speed where a down shift is likely to occur, under power the vehicles are great to drive but not good enough under moderate low rpm traffic manouvers, as I write I consider maybe I should raise the drivers request for that area I'm having an issue as this may reduce the TQ throttle control intervention. I have reduced Transmission Airmass TQ limit to zero and Airmass tipin to zero without any sucess, I also reduced downshif torque reduction in case this was causing the problem with no real improvemnet.
IPC error, I have not been able to eliminate this totally around 0.9-1.0 load, which is as boost comes on, I have calculated the inverse TQ and used the dyno increased torque as the model for all TQ mapped points. It is like there is an internal reference to the throttle prediction airflow, which makes me wonder has anyone played with the throttlebody airflow predicted airflow on a boosted car with a stock throttle. I see a number of people have had issues when fitting other throttles and clearly the airflow for a given angle wil be significantly different. The WOT entry point does influence the IPC error and according to HP the driver demand table is ignored, I assume it bends towards WOT and during the bend it logs IPC errors but at WOT the errors again drop to zero. The WOT entry point needs to be reduced in a blown application in order to enrichen progressively and not run too lean under boost.
Any thoughts or comments are welcome.
