Results 1 to 11 of 11
Thread: Tuning A 6.0L Powerstroke
    May 2013
    29
    Hello all I am new to the tuning world and trying to learn. I bought my HPTuner about a year or so to tune on chevy ecotec that I am putting in a off road buggy.
    I seen hpt supported the 6.0L PSD now so I bought credits to unlock unlock my truck. I read and google tuning a 6.0L but could find much to help me with what I should change and most important what not to change... any guidance would be appreciate... Thanks Craig...
    craig stock tune 6.0l 2004 f250 - STOCK.hpt
    Mar 2013
    45
    Towing.hpt Here try this and compare its a 2006 but the concept is the same.
    May 2013
    29
    Thank you...Going to mess around with it a little make small changes...
    May 2013
    29
    Got a question? When I first start my truck the exhaust has a nice rumbling sound then get quit...Is there a why to tune the veins to stay open at idle then just off idle they close and then work as they "stock"....
    Mar 2013
    45
    you can move your vgt or veins some you will have to play around with that to see what truck likes. also the exaust your running will make a difference in sound as well.
    May 2013
    29
    Ok thanks will mess around with the vgt...I am running 4" straight pipe...
    Advanced Tuner RandomEnthusiast's Avatar
    Feb 2016
    Texas
    333
    To get that nasty idle bump your desired boost at idle down and adjust veins more open. I've played with it. Takes a while but it should work.
    May 2013
    29
    Where do you make the changes in hp tuner?
    Feb 2016
    Texas
    333
    This worked on an 04 so not sure if it works on newer 05-07 trucks. I was really just playing with it and I deleted it afterwards so I don't even have the file anymore so not exactly sure how this will do but it should do it. idle 2.pngidle.png
    May 2013
    29
    Adjusted the cells a good bit higher and didn't make much of a change. How much of a change does it take?
    Feb 2016
    Texas
    333
    Hmm. Did you adjust the expected? I can't think of what other tables I modified as well.
