Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: Timing Dip at Beginning of WOT takeoff
    Feb 2013
    glennville ga
    168
    Thank god someone had a fix. Would have never thought the fuse pulled was the problem. Mines been pulled since day one. The tbss guys swear by pulling the traction control fuse. Ill give this a try. Thanks.
    2000 silverado rcsb lq4/4l80e. Custom s480 turbo setup. 93oct meth injected. SD Tuned by me.
    2007 tbss ls2/4l80e. Nitrous!!! MAF Only Tuned by me.
    Jan 2016
    25
    Yes Joe says hes been fighting that fallacy for a while. Nice to have the launch not feel like my work van taking off from a light.
    Sep 2008
    LI NY
    104
    I was the only one that suggested not to, it does more harm than good. In my trans tune for my '08, I have the minimum settings and have no throttle cut or dip in timing. But my ecm is slightly different, I have the fast torque tables, and the 07's don't. Strange how GM has so many variables from year to year.
    Feb 2013
    glennville ga
    168
    Well i tried this on my tbss and it didnt help me. Any other ideas on this. Mines pulling timing and cutting etc back to 50% on first gear take off. Sucks!!!
    Jan 2016
    25
    Sorry to hear. Went to the track this weekend and it's fixed my problems 100%.
  6. #26
    Feb 2013
    glennville ga
    168
    Damn. U said joe helped u from west coast 32?? If so i pm him on tbss owners. Are there any other tricks that u might have left out? I tried everything u mentioned. I even reinstalled fuse. No luck!!
  7. #27
    Jan 2016
    25
    Fuses installed
    Stall tq management maxed out
    Brake tq management enabled
    Brake tq management table maxed out
    Torque reduction 1+. Not 0'd.
    Torque reduction duration 0.1+. Not 0'd.
    Tip in limiting disabled
    TCS spark, fuel cut, and etc disabled
    TCS enable temp at 280
    I believe that's everything.
  8. #28
    Feb 2013
    glennville ga
    168
    I pretty much had all that. Ill give it another try and check fuses over once more. Thanks for your help. Greatly appreciated!!
  9. #29
    Feb 2013
    glennville ga
    168
    So u just been disabling tcs and stabilitrak with the button? Is it really needed? I didnt notice any stabilitrak issues without it like i did with the stock tune.
  10. #30
    Jan 2016
    25
    Correct. With the fuses pulled I was only getting a huge timing dip when brake launching it around 2k rpms. It would pull about 15 degres for 0.8 secs roughly. Which is significant for the 60 foot. Now with all the settings like I mentioned and the tcs/stabilitrak deactivated with the shifter button, I am getting full power/commanded timing on the launch. The abs and stabilitrak fuses being pulled makes the ecm use brake torque management no matter if it's disabled or not.
  11. #31
    Tuning Addict
    6,802
    I've been finding more and more that a lot of newer vehicle such as the 5th gen vehicles are like this too... I am no longer disabling brake torque management... I've even noticed if it's disabled - you can't use the shifter button to "officially" kill it anymore - it will say it's disabled, but it still pulls a hefty chunk of timing to try to kill wheel spin... Just goes to show that just because you think you have it set right in the tune - it always isn't
    ~Greg Huggins~
  12. #32
    Feb 2013
    glennville ga
    168
    I tried it tonight and it seemed like it worked. Ill log it tom and recheck. Thanks for all the help guys.
