Results 1 to 16 of 16
Thread: HPTUNERS 3.2 Upgrade Help
    A few days ago I downloaded the 3.2 beta version to my VCM Suite software. I then looked at a few P01 and P59 PCM Flex Fuel files. For some reason the next day I was not able to access the Blend Factor table in any of the files I looked at whereas the day before I was able to view that table. Its not showing up in the files at all. I went back and re-did the 3.2 upgrade just in case something got messed up during the first time but I'm still not able to view that table. Is there a Hptuners expert out there that can help me out.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    3.2 isn't beta
    Make sure you're in advanced view. edit-->view-->advanced
    That's the usual cause of this "issue"
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    LOL....oh its not. Its in "Advance Mode". I checked 10 plus times.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Can you post a copy of the tune and exactly where/what is missing, I'm curious now
    2002 Flex Fuel 5.3 Tahoe.hpt 2005 flex fuel 5.3 avalanche.hpt
    Here you go. The Blend Factor table should be under the Engine>Fuel>Open & Close Loop section. Then you would look to the top left under Open loop. It should be under the STFT enable/disable table.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Weird.
    Guess you should try emailing support and ask for it to be added. Not sure why it disappeared?
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    So can you see it in both files?
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    I can't see it in either in the production release or beta
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
    HPT Employee Engineer@HPT's Avatar
    Jan 2015
    fecadefa
    615
    I am not showing that we've ever had that parameter added for those two OS you posted. I've added this parameter to two specific OS earlier this summer. You can e-mail support and request it to be added to others.
    http://ls1tech.com/forums/pcm-diagno...estions-2.html
    Check out post 35 and 45's images. Its from a different site so I hope its alright to post this here.
    I already sent support a request yesterday (Ticket #57837) for help with this on both of those OS.
    I was able to view that table briefly.
    2004 Flex Fuel Avalanche with Blend Factor.hpt
    Looks like I was looking at a P59 PCM but with a different OS. 12587603 OS on a P59 PCM has the Blend Factor table. Others may have it too. Wonder if it can be added to my P01 PCM with 12216125 OS?
    Jan 2015
    fecadefa
    615
    Correct, 12587603 and 12587604 are the only two OS that have it currently.
    Can it be swapped into the two OS's mentioned in post #5?
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Find the parameter ID numbers and email them along with the names of the parameters and both tunes to [email protected] for whatever you want added and they'll take care of it if it can be done. Make it easy on them by providing both tunes and the parameter #'s
    i.e. [ECM 12449] open loop blend factor
    I sent that number to Clayton (12449) @ support with the 603 OS hptuners file.
    2004 GTO.hpt
    Can anyone tell me if this file (OS 12587604) have full Flex Fuel capabilities?
