Results 1 to 7 of 7
Thread: Idle kicks up to 2k after reving and while coasting
    Tuner in Training jgibbons's Avatar
    Oct 2016
    colorado springs, CO
    25
    Angry Idle kicks up to 2k after reving and while coasting
    please help. i feel like i'm so close. ANY pointers are appreciated.
    5.3
    e85
    80lb injectors
    223/227 cam
    twin 61mm t4 turbos
    10lb springs in wg
    13,564
    Fuel injectors do not look you have them set up right, the flow rate table still shows around 50ish lb injectors. You need to put in the right flow rate for 80lb/hr injectors.
    MAF fail high needs to be set to 0hz still. Remove your MAF channels from the scanner too.
    Oct 2016
    25
    thanks for pointing that out. i have updated injector info. I will be able to test tonight.. but any other ideas if that doesnt work? or general tune advice??
    Oct 2016
    25
    car wont start with proper injector data. anyone have some time to look over my tune and wanna make some money?
    Oct 2016
    25
    my injectors are more like 94.3 lb injectors.
    no maf.
    2bar.
    10 lb springs in wg's
    appears to be 0 boost or exhaust leak.
    tr6060 manual trans.
    my friend seems to think i dont have nearly enough timing. ill post my latest tune in a moment and log from cold. after its warm then it starts and drives. random idle dips and then wont drop revs below 2000/1900. ill gladly pay for a remote tune.
    Oct 2016
    25
    i think i've cleared this up. i will start a new thread for the next issue
    Oct 2008
    Perth Australia
    161
    What was the issue ?
    High idle and high rolling idle is to do with the idle airflow tables, throttle cracker/follower etc
