Hi All,
Ok so I have a 2000 VT Holden with a LS1 it has a cheap alloy intake manifold and a cheap 102mm throttle body on it.TB blade set to lowest rpm and sensor unplug reset carried out. I can't get the idle below 1300ishrpm. I can't find any leaks. But if I command zero idle air flow it makes no difference at all. I expected the car would die once start up air flow had decayed. If I add base running idle airflow I can raise the rpm. When it's cold it starts at around 950rpm and slowly rises. I'm sure the issue lies with the cheap throttle body but I cant fit a standard one on to the big alloy intake to test.
I will attach a copy of the tune and log and a copy of the stock tune. I would really appreciate it if someone has an idea or a process to confirm the cheap parts are at fault.
Any comments welcome.
