Results 1 to 5 of 5
Thread: stupid question
    May 2010
    250
    stupid question
    where do I adjust for wide open throttle ?
    Been a while and I cant remember where ?
    Thank you.... also what is the ideal afr for WOT ? Making about 700 hp 11.7 is what I think I should be shooting for ?
    May 2010
    250
    ok found it power enrich eq ratio vs rpm
    13,564
    700hp with what?
    What fuel?
    Details go far with choosing a good target AFR. The EQ Ratio is the place to select your WOT AFR or the boost ratio if you are running a 2 or 3 bar OS can be used. It's pretty much a select a target number and forget it table, if you are still off on your wideband for fueling you'd adjust your VE/MAF tables to bring in fuel or take fuel away.
    May 2010
    250
    457 cid ls2 246/262 cam 99 Camaro 11.5:1 compression
    sd tune custom os
    Feb 2016
    Texas
    534
    11.7 is a little fatter than id'e be running something like that. maybe start off in the 12.0 area and keep it under 12.9. some people might have different opinion's. I tend to run more timing, more fuel. Some people like less timing and less fuel up to 13.5 I have seen. But I would advise against anything above 12.7 honestly. Might get flamed for this but oh well.
