looking over some logs trying to solve a lean spike on throttle transitions I found a few times where the map and throttle values were reached but the commanded never changed from stoich. but other times it does. im thinking this might be one of my issues. I have often wondered about my x link but
at the same time the scanner is seeing my tps being above my setting for pe to come on frame 6781 is one example, 7054 again all delays are zeroed out
I need some guidance please.
