Anyone running the BTR stage 4 truck cam?
I picked one up and am wondering if anyone had any luck on the idle side getting a good idle?
Stage 4 is a fairly aggressive cam. To get a smoother idle you will probably have to raise the idle rpm id imagine.
BTR Stage 4 Truck cam is 224/230 111 +2 won't be that hard to idle. A looser converter will help a lot. I just did an ASA cam (226/236 110) in a 53 with a stock converter and it wasn't that hard to get a stable idle.
This a 5.3 swapped into 97 truck with btr stage 4, idle is pretty decent.
https://www.facebook.com/15533336815...3851281210497/
Have one in my 06 idled fine with stock tb. Got a ported 3 bolt tb and I've been fighting with it since. 3200 circle d converter
