just use the cyl airmas and dynamic airflow and put them together in the timeline chart and u get a virtual dyno graph, cyl air is torque and dynamic air is hp
Thanks, but I'm not exactly sure what timeline chart you're talking about + what units to use...
Are you talking about the Chart vs. Time chart in VCM Scanner? I just replaced the 2 LTFT ones with MAF Cyl Airmass (V8) + Dynamic Airflow and the MAF is reading around 0.10-0.72(g) and the Dynamic Air(g/s) isn't reading at all
How would I get a horsepower and torque reading from that???
Can you upload a screenshot or tell me more please?
u will have to log dynamic air if ur not already, or u could just the torque calc and a hp calc and put them together on the chart v time and u get a virtual dyno, i found the hp calc to be close to engine hp like the torque calc is close if u just want a basic reading of what is going on, ill see if i can find my info n put it up when im back on the laptop
looks like the calc hp/torque are just the same as the dynamic air/ cyl air, here is a part of one of my logs pity the readings arnt spot on
Thanks mate.
I finally got my 1st (MAX) horsepower and torque readings yesterday after work
(Had more technical difficulties before that.. HP and torque gauges wouldn't work.. selected a different torque gauge and that fixed the prob.)
(Also spewing because I recorded a run on my way to work in the morning and just when the LS1 warmed up and I turned into a large main open road and dropped the hammer, VCM Suite froze! All that wasted rubber and wear n tear + waking up at 5:40am for nothing )
389 HP (IAT at 34 degrees C. Damn traffic. Felt way-down on power.. compared to driving when it's cold/winter)
413 Nm (IAT at 27 degrees C.)
Gear: 1st
Baro pressure: 99.28 kPa.
Engine mods: usual bolt-ons.
So I'm thinking..
- the power reading is a little high (I hope not). Like by 10%. Was expecting that figure after I had tuned it.
- the power reading is at the engine obviously, not wheels.
- the torque reading seems to be 100% accurate if it was taken from the rear wheels. If I get the standard LS1 torque figure, add around 40 Nm to it (due to my mods), then multiply that by 0.85 (drivetrain loss), then it's spot on.
Also, I want to put this here in case it helps people
Taken from this thread http://www.hptuners.com/forum/showth...e-timing-table
Hmm, I wonder what my hp/torque readings/difference will be in 3rd gear. Will post results..
