Hello Guys I am wondering if there is someone out there that can help me set up my vss using HPTuners? My idle is poor and it is hunting around. I see where you can change the parameters in the software but I don't want to mess it up. Thanks!
Save a default tune with all the default settings you start with. This way you always have somewhere to start over. I don't know much about using speed sensor with hp tuners but it should be just another sensor to setup.
I hope I am doing this right as I am struggling on attaching a file. I did spend the last two nights on the internet searching for VSS info and I did get it adjusted some but I'm not sure if it is correct. It does run 90% better but it still died once when I pushed in the clutch tonight and it also threw a code tonight. p0502 vss A circuit low (pending, current)
