Im having an issue setting a 2 bar sd tune flash. When I flash the car
after saving the file on 2 bar sdrtt my map sensor goes haywire. If I
reflash with rtt 1 bar enhanced flash and enter values for 2 bar sensor, map kpa is fine
and I can adjust the ve map in real time. when I switch to 2 bar map and check values for
map sensor which are correct I get a bad value on scanner for map sensor. The car runs
but not proper and maps sensor reacts like the data posted
Ive attached a map and data. Ive tried the other 2bar
and 3 bar sd modes and they do same thing. also on the sd enhanced mode
wich I used to get a base in I change the values for the map sensor and the
kpa reads correctly. I test this with a pressure tool and it reads
correctly on the scanner. If you look at the data you can see map sensor is not working properly.
Im not sure how else to explain it.
