Can this be done?
I'm at my wits end trying to get my 68 Camaro rolling. It has a cammed LS3 in it and I cant get it running good enough to even make it down my street without stalling and going into some type of limp mode from code PO300.
It seems like every time I start the car it acts different. No matter what I try todo with the VE tables it seems to want to run rich as hell. I'm wondering if it's a losing battle since I found out that the original OS in this ECM was replaced with a 2bar (I bought the ECM used). Is this engine tunable with the 2bar OS? Will the VE tables just not play nice with my stock LS3 MAP?
Should I just disable the PO300 code? Never had to do that before as I always just adjusted sensitivity with a cam. Is the PO300 probably coming from the rich condition?
If it matters I also got code P1381, seeing ti was related to the BCM (which I don;t have) I set that to no error reported.
