Results 1 to 5 of 5
Thread: Ford mass value for engine displacement
    Advanced Tuner GapRider's Avatar
    Nov 2015
    South Carolina
    246
    I've read that Ford uses air mass to state engine displacement.
    Calculating displacement for the coyote engine I get .0015628 lbm (using Ford 100* and 29.92 inHg for dry air density).
    I'm confused when I see the parameter Engine>General>Engine>Engine Displacement at .00167 lbm?
    What have I got wrong?
    2019 C7 Stingray M7 - long tube headers, 6.30/6.22 226/238 cam, supporting stuff, DOD and VVT delete.
    Stock everything else
    Jan 2013
    Hawaii
    2,101
    I get air density of .07090 LB/Ft^3 at 100*F. 5L is 0.176573Ft^3. .0709 * .176573= .012519 divide that by 8 and get .001565.
    STP - commonly used in the Imperial and USA system of units - as air at 60*F (520*R) and 14.696 psia (15.6*C, 1 atm)
    If I use air density at 60*f .08633 LB/Ft^3 I get .001685. I don't think the engine is quite 5L, 4.952L actually, which should account for the small difference. This value must be based on STP not fords usual 100*f and 29.92inHg.
    Nov 2015
    South Carolina
    246
    OK thanks, I bet the different standard temperature is the reason, I hadn't thought of that
    Oct 2007
    Crawfordville, FL
    2,412
    Yep, on the N/A engines, Ford uses a different temp.
    Eric Brooks
    HP Tuners, LLC
    Nov 2015
    South Carolina
    246
    good to have that confirmation, thanks Eric
