I have a 2003 ram 3500 5.9 manual trans, how do I go about raising the boost pressure beyond the 20 PSI stock limit? I am having trouble locating the wastegate control function.
Thanks in advance!
Casey
Thanks in advance!
Casey
Never mind, the truck only has a waste gate, I assumed it was like the later model 5.9 with a solenoid.
More fuel will make it creep, remove boost limit, add manual boost controller or take the hose off the gate if you want more than that.
2003 305/555 QCSB Cummins
Piston/rod/sleeve/fire ring/dual CP3/300 overs
Super Stick NV5600
S366/S480
