Results 1 to 4 of 4
Thread: Foot braking
    Aug 2016
    38
    Foot braking
    I was curious of what kind of AFR should I have wile foot braking on a turbo setup
    Aug 2016
    38
    No one?
    13,565
    Put it this way, you wouldn't want to be running 14.68 AFR while building boost on the foot brake.
    You wouldn't want to pop a cylinder in the beams or on the road somewhere. It will already be in PE if you are in boost so that AFR is what you'd want.
    Check out this thread. As 5FDP stated if your in boost you should be in PE (or BE) if you have your tables setup correctly.
    Desired AFR is up to you, again as stated you don't want to be at stoich, but you can run it a little leaner or a bit richer to get the spool you want
    http://www.hptuners.com/forum/showth...PE-Table-Usage
