Please describe your ways of finding the voltage offsets between the wideband monitor display and the hpt scanner readout.
My way is to start the vehicle for a few seconds then shut it off and compare the scanner readouts with the wideband monitor. Adjust the offset accordingly until both read the same.
However that's with the motor off so hopefully that's a good enough method that will give accuracy at wot.
