Results 1 to 6 of 6
Thread: E38 connector part numbers
    Jul 2016
    5
    Does anyone know the part numbers for the E38 type ECM connector parts and pieces ?
    I want to build a bench programming harness.
    Thank you
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I don't have the part numbers handy, but Mouser carries them.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    pins might be Female Molex MX64 pin Mouser 538-33467-0005:
    http://www.mouser.com/ProductDetail/...hYiq3KjA%3D%3D
    If you find the correct housing post it here I want some too.
    Here is a list of some of the housings... the right one may just be in there somewhere:
    http://www.mouser.com/search/refine....&Ntt=163190304
    Or for $60 you can get both complete with wires and pins, you crimp yourself.
    http://www.ebay.com/itm/New-2007-201...-/141849617831
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
    You only need the 34566-0103 connector for bench programming the E38
    -Greg
    2009 Maverick Silver G8 GXP M6 - 586hp
    Engine Mods: TVS 2300 Magnacharger ARH 1 7/8" long tubes with catted x-pipe
    Drivetrain Mods: Ram Dual Disc Clutch
    Suspension Mods: Pedders/Wretched basic drag pack - BMR trailing arms
    Misc Mods: Jamesbiz Catch can - GRRRR8 Heater hose relo kit
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    X1 Housing:
    http://www.digikey.com/product-detai...413-ND/3044539
    X2 Housing:
    http://www.digikey.com/product-detai...415-ND/3044540
    Common housing cover:
    http://www.digikey.com/product-detai...409-ND/3044537
    Common pins
    http://www.digikey.com/product-detai...9CT-ND/5287252
    They offer 2 different wire exit angles since they are 90 degree connectors....not sure if it matters to you
    May 2015
    Minneapolis-St. Paul
    23
    Do you wire this similar to how they showed in the EFI live bench harness?
