Results 1 to 8 of 8
Thread: 5.3 DOD disable HELP!
    Oct 2016
    Creedmoor
    3
    I have a 2007.5 Tahoe that had a DOD lifter fail. The DOD delete was done, and I disabled the DTC codes & master DOD setting, but it's still defaulting to 4 cylinder mode. What did I miss because I'm at a loss, and I've been searching the forums for about 2 hours, and haven't found a answer. I attached the file below any help would be greatly appreciated!
    13,565
    The master disable is really all you have to do, if you wrote the file to the car and it didn't work then just disable it by gear and PRNDL.
    Set the 3th and 4th gear to 1 to disable it and same with the PRNDL, set those to 1 for D3 and D4.
    Aug 2016
    JRane,
    Did you also change the cam to a non-DOD cam? I just finished my DoD delete and everything went perfect. Find my file attached
    Oct 2016
    Creedmoor
    3
    Which trans settings are those?
    Quote Originally Posted by thxone View Post
    JRane,
    Yes I changed the cam out as well.
    13,565
    They aren't transmission settings, they are DoD settings under the DoD enable/disable box.
    You must be in advanced view to see everything. Edit > view.
    Oct 2016
    Creedmoor
    3
    I'll try that & see if it works. Thanks
    Dec 2015
    Oman
    38
    Hi, what could go wrong if i disable DOD only and no modification being done on the Engine??????. I thought it will just prevent the engine from running in 4 cylinder mode.
    13,565
    Quote Originally Posted by alsediri85 View Post
    Nothing could really go wrong, tons of people just disabled the DoD in the tune and do nothing else. It just keeps it in V8 mode all the time. All the DoD/AFM parts will still be in the engine and someday could fail still but the chances are less if they aren't being used anymore.
