Results 1 to 5 of 5
Thread: Request assistance on very rich idle
    Sep 2016
    5
    Greetings,
    I purchased a 2000 T/A with a modified LS1 (799 Heads, Cam, Long Tubes) and unfortunately there was no build data with the car. It has a tune and runs decent however it seems to run very rich at idle/startup.
    I pulled a cold start log file of the car, and I am trying to determine if it's the tune or if the O2s are on their way out.
    I've attached the log file and the tune and would appreciate any thoughts or feedback of where to start.
    EDIT:
    Stock 2000 LS1 Injectors
    Cam specs are unknown
    Thanks in advance!
    13,565
    Something is for sure off with those o2 sensors, be it wiring or both are slowly failing.
    They don't switch much and stay very low on mv for long periods of time and the STFT are having to make huge corrections.
    Sep 2016
    5
    That's what I was wondering, it seems they are out of range until the STFT brings in enough fuel that they start reading in range, but that's an uneducated guess at this point. I am thinking that a wideband would tell the tale, just haven't gotten to the point of getting one yet.
    Sep 2016
    5
    Update:
    Idle Air was higher than I would have expected and idle timing was 35 degrees
    Dropped Idle air and reduced idle timing to 12 degrees and my eyes no longer burn from the NOX at idle. It's surging a little, but I will chip away at that.
    Tuner in Training CivilSavage's Avatar
    Sep 2016
    Denver, Colorado
    31
    Just wondering, what will you do to chip away at the surging? I have the same problem....also rpm's dip way too low at times.
