On really hard shifts (m6 manual) I am occasionally getting a boost spike that causes KR every time. I'm running about 9.5 psi. And looking at my logs I see boost spike to 13-14 psi when doing something like a hard shift from 2nd to 3rd. These boost spikes are literally milliseconds long...but they are enough to trigger knock and make the KR go crazy.
It must have to do with a shift and resulting abrupt (and large) swings in the boost/vac/boost sequence from the bypass valve shutting and opening so quickly. It only happens on higher rpm shifts. The only way I can figure it is that the blower is spun up and really huffing some air and hits the engine with more boost than it can consume for a brief instant. And it's usually a 2-3 shift or a 3-4 shift (higher engine loads after the shift). Never seems to happen on a 1-2 shift. Maybe the engine can rev up and consume that boost as quick as it can come in lower engine load conditions...but at higher loads after the shift its causes a pile up of boost?
Anyone have any solutions on how to deal with this? I slowed my throttle blade opening rate down. But HP Tuners settings doesn't allow you that much control over the opening rate. I've also heard of people putting carb jets into the boost/vac line that controls the bypass valve. Anyone ever tried this?
Perhaps the next big leap in PD blower technology is the ability to have variable control of the bypass valve closing rate...
