Results 1 to 19 of 19
Thread: Transient fuel setting?
    Aug 2016
    46
    Is there a setting in transient fuel tab that will help with throttle response and lag/hiccuping when hard acceleration is made at lower RPM's?
    Nov 2009
    All Around
    3,149
    yes, you can adjust manifold volume
    Tuning Addict
    Jan 2015
    6,804
    Only adjust it if it's a lean out issue during stomps or more rarely - overly rich during stomps... This won't do anything for timing being pulled out during stomps...
    ~Greg Huggins~
    Aug 2016
    46
    Is that the only tab to adjust?
    Nov 2009
    All Around
    3,149
    you need to post a log of whats going on, the issue will be more clear
    Advanced Tuner ttz06vette's Avatar
    Sep 2008
    Charlotte, NC.
    242
    So the manifold volume only impacts stomp lag? I was hoping it also would help with lean tip in on light throttle as well.
    My understanding is that manifold volume impacts on all transient fueling through a mathematical model, tip-in and tip-out included, so I would suggest getting it right first and then continuing with other parameters if needed.
    where is manifold volume located in the editor?
    Jan 2014
    Australia
    1,983
    Quote Originally Posted by andrew1988 View Post
    fuel transient section, u may still have to request it also if u cant see it
    Sep 2006
    Syracuse, New York
    299
    Anyone know how Tranisent Fueling differs on the E40? We don't have a Manifold Volume parameter. I have increased Transient Warmup Base Mass from the stock value of 10 to 500 (currently) and still have lean spikes doing major throttle transitions - enough that there is a hesitation before fueling catches up
    Tuning Addict
    Jan 2015
    6,804
    Mind posting your tune - it can be a base file - doesn't have to be your current tune... I thought all gen 4's had this capability and just needed to be requested? I know it's not available on gen 3's...
    IF it's indeed not available all you have to do is modify your main transient table - it's actually not that hard to do...
    ~Greg Huggins~
    Sep 2006
    Syracuse, New York
    299
    Sure. I don't have my computer with me, so the latest file I have is from a backup from two months ago
    Tuning Addict
    Jan 2015
    6,804
    Quote Originally Posted by HackAbuse View Post
    Have you tried requesting it? I just double checked and some of my E40 cals have the manifold volume... You may just need to request it from HP Tuners... If it's not available I can tell you what to roughly change...
    ~Greg Huggins~
    Sep 2006
    Syracuse, New York
    299
    What's the parameter number on the E40s you've seen it on? I requested for #12003
    Quote Originally Posted by HPTunersSupport
    Hi,
    Unfortunately parameter 12003 - Intake Manifold Volume doesn't exist in the E40 controller.
    Tuning Addict
    Jan 2015
    6,804
    Well I guess I'm going blind Just went back and looked at the ones I thought were E40's, only they were E38's
    Anyway, under transient fueling - impact factor - gas - start at around 80kpa and multiply that entire row by 1.1 then next row 1.2 then next row 1.3... That should get you much closer for a boosted application. If your not boosted, multiply by 1.05, 1.1 and 1.15... Do the same to the evap factor table for gas as well since they kind of go hand and hand - they'll both add fuel, so keep that in mind on how much you increase them by... I've never messed with the accel/decal table even though I imagine that could do something for decels?
    ~Greg Huggins~
    Sep 2006
    Syracuse, New York
    299
    I'll give it a shot when I get the car driving again. Having an issue with clutch hydraulics not bleeding properly right now and I'm worried the master cylinder is shot. May have to wait until spring so I can ditch the T56 for a 4L80
    Sep 2006
    Syracuse, New York
    299
    Got the trans working well again and tested transients out today the way you described. Reset all transient values back to stock then applied a similar scheme to what you described with an increase of 25% at the uppermost bound. That one adjustment made it VERY close. So that seems to be the trick for the E40. I had been on the right track previously, but was changing the wrong values and not making it any better. Thanks again
    Tuning Addict
    Jan 2015
    6,804
    Just a few easy rules to remember on transients... First don't change them where you typically drive or idle - I don't go any lower than 80kpa now - it will change the air fuel at which your wanting to run - in other words you increase it with something like a cam for instance where your rpm fluctuates up and down from the natural lope - it will idle at a richer air fuel ratio then lean back out at lower map values like where you cruise - I had one idling at a 14.1 afr doing this then cruising at a 14.7ish afr Secondly - don't recommend changing individual cells or sections from the left to right - only change vertical lines as a unison of those map kpa cells... Third - if you change an entire table from another OE tune - make sure you change all of the transient tables from that OE tune - you can wind up with all sorts of really lean tip in conditions or other problems...
    Follow the basics - use them to your advantage how you will and you should be OK
    ~Greg Huggins~
    Sep 2006
    Syracuse, New York
    299
    The first time I actually tried making transient changes, I actually flooded the engine so bad during cranking that it wouldnt turn over, so I know how sensitive some of those changes can be lol.
