What table controls your commanded afr between the time your engine starts and then go's into closed loop, i have tried adjusting the open loop eq ratio table in the temp area's i would like to make leaner but nothing happens. The only time the table will change any thing is when i put the whole table to 1 but the cold starts suck, it's like it's only looking at the table as a hole and not temp vs map and then using some other adder table?. Other then this im realy happy with this tune. Thanks for any help...
