I'm in a rush so can't type the full explanation right now, but the short version is there ISN'T knock retard on tip in in the last log you posted. There were only two relatively small spots where you had any "real" knock at all. The max was 2*.
Everything else you see is being caused by something else. Burst KR or who knows what. "total knock retard" includes things that aren't actually knock.
Again, what you are seeing is not actual knock retard.
Transient fueling controls fuel on tip in / tip out. Easiest thing to change is manifold volume, try increasing is 20-30% if it's lean on tip in and see what happens.
I could be wrong if your latest logs are different, but this is 100% true based on the last log you posted.
Red is real knock retard from the sensors detecting knock...
Green is "total" knock retard that includes things like burst KR and some others. The red one is the one you need to worry about as far as actual knock from the knock sensors goes.
