Results 1 to 5 of 5
Thread: trying to learn lambda
    Mar 2015
    north alabama
    22
    ok probably dumb question got everything set up to scan lambda for now I have commanded lambda at 1.0 across the board. I am beginning to try and tune ve and I think I can use the pre loaded lambda chart as long as my commanded stays at 1.0. what I am running into and would like to learn or figure out is the preloaded lambda chart will say .98 at idle and my commanded lambda I set up is reading 1.02. I know it is simple because its very close across the board if eq says 1.03 my lambda error will say .97 I know its simple and I don't like asking but any help is appreciated
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post your layout also
    Also, I don't understand what you're asking.
    Commanded lambda stays = 1 that entire log, which I don't necessarily think is a good thing unless you like being lean.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Mar 2015
    north alabama
    22
    here is my graph setup. I am no expert just tune on my own truck but everything I have read when ve tuning do I not want a commanded 1? I am commanding a 14.3 afr at 1 I had turned pe and dfco off because I had not figured out my commanded error so I didn't want those throwing off my numbers. I am no expert and please correct me if I am wrong but doing it the way I did I feel good about base ve I am lambda 1 or 14.2-14.4 across the board. I do want to figure out lambda error so I can make some scans and dial in my pe which seems to be real close now.
    thanks for the help
    Oct 2011
    Australia
    175
    For safety sake turn on your PE. You can setup a filter to filter that data.
    For VE simply make a graph from your VE table X & Y axis. Log EQ Error Ratio under Maths --> Lambda & AFR, you could simply use your Lambda Error graph, just change the parameter to be logged and ensure X & Y axis for the graph are the same as your VE table. In that same graph setup a filter to filter out PE data, you can also take the filtering a lot further but you will need to read up on that.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by hrobb11507 View Post
    thanks for the help
    No--the idea is to compare actual lambda from a WB vs. commanded lambda and correct accordingly. Making it just a flat 1 makes the math look easy, but HPTuners does the math for you so you're just running it too lean for nothing.
    I added some stuff to your charts so that it has commanded lambda, wideband lambda and lambda error.
    If you post your tune I can show you how to make a graph which is really what you need.
    Test.Layout.xml
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
