Results 1 to 5 of 5
Thread: Wot rpm problem 3ar sd tuning
    Jul 2007
    12
    Wot rpm problem 3bar sd tuning
    the problem is at wot it is not past the 3400 rpm
    100% tps
    10.5 timing
    12.5 afr
    150 kpa map
    3.2 hp version
    do you think that i miss some thing in tuning or is it normal for 4200 torque converter hear is the log and the tuning
    333333333333333333333333.hpl
    last one spark change.hpt
    the car is f- body 95 swap LS
    3bar sd tuning
    5.3 engine 1200 injector
    gt47 turbo
    9 inch deff
    th400 4200 torque converter
    thanks for any help
    13,565
    What kind of MAP are you using?
    I've never seen MAP linear and offset readings like that before. You also don't want to run a duramax 3.3 MAP on a gas car. If it's a 3 bar OS you only want to run a 3 bar MAP with correct linear and offset settings.
    Also you MAF dtc's aren't set correctly, they need to be on first error for speed density tuning.
    Jul 2007
    12
    5FDP thanks
    it is 12623671 3.3 MAP
    to run 3 bar MAP with correct linear and offset settings with 3 bar os
    what 3 bar map sensor you suggested part number or internet link pleas
    abut the dtc i will change it
    Apr 2006
    western NY
    339
    2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
    LS1Tech sig KRAZY K 2000 TA
    Jul 2007
    12
    Quote Originally Posted by Throttle View Post
    thank you for your help
