Results 1 to 3 of 3
Thread: maf hz afr error histogram?
    Jul 2015
    4
    Hi,
    I'm trying to dial in my maf, and I'm not sure how to set up a maf hz vs afr error histogram in the vcm scanner. Is that a histogram that should be pre loaded into the vcm scanner? I recently upgraded from hp tuners basic to pro. And in my vcm scanner, I only have 7 pre loaded histograms. I have a histogram for ve tuning, rpm vs map. But nothing for maf tuning. Thanks, I'm kind of lost
    13,564
    http://www.hptuners.com/forum/showth...tarted-Threads
    Should be a thing is this thread.
    Jul 2015
    4
    I found it, I just had to import the .hst
