4l80e swap when i put into over drive at wot it wont shift into 3rd. when i put it into d it will shift to 3rd but for safety i want it to work in od. please look at my tune me and a friend cant figure it out
98 trans am stock 5.3,3 bar sd, 98 pcm swaped for 99+ 411 pcm, ls6 cam, ls6 intake, procharged d-1 3.7 pulley 12 psi now! twin intercooled stock bypass and 40 mm blow off,long tube ss 1 3/4 headers 3 inch cat back lol, siemens deka 110324 80# injectors, 40 psi afpr -8 feed -6 return dual walbro pumps ,4l80e trans, ford 9inch 3.25 gears, prostars M\T et streets 28 inch, soon to have meth
On a 4L80e you never want to have the shift selector is D4 when doing anything WOT, you run the risk of breaking the roller clutch.
Side note, just poking around your tune you missed a step with your speed density setup. MAF dtc's need to be on first error and not second error for SD.
thanks so much!!!!! i thought i heard that before
ses enabled???? or them them unchecked?
If you don't want the light, just leave them unchecked.
