ADDED NEW FILES - MORE RECENT
Issues:
Knock during neutral revving and fast throttle transitions
Experiencing lean tip ins when warming up (after 30 mins or so, lean tip ins are not an issue).
I have been trying different things so the VE is still a bit odd, but much better since fuel pump issue was resolved.
I wanted to see if anyone would be willing to look over my "tune" (not on a dyno). Or, hopefully someone else has done this swap and tuned it up very nice like!
I have been cruising the HP Tuner forum and absorbing as much as I could, and have arrived where I am now.
The vehicle drives pretty well once up to temp. Plenty of room for improvement.
I have attached a recent drive log and the tune that it was running during that log (still in progress).
2000 LS1 engine, stock from the heads down, including exhaust manifolds. 2.5" duals, no cats.
6 speed manual, 4.10 gears.
2013 LSA blower with ZL1 lid, stock pulleys, running AFCO heat exchanger, 92mm DBC throttle.
3bar SD OS, stock LSA GM 52.4# injectors. Boost referenced fuel pressure regulator.
3_BAR 9-17-2016 023.hpt
9-17-2016 Tune 022 Log 002.hpl
