Results 1 to 3 of 3
Thread: Transform help
    Transform help
    Need help with a transform. I have several laboratory grade non-linear (temp, egt, linear ride height) 0-5 volt inputs that worked fine in all previous version. Not suported in 3.xx! HPTuners tech support has been no help.
    So trying to develope something close with no luck.
    Oil temp sensor:
    range
    .522 volts dc = 60F
    4.64 volts dc = 310f
    tried volts/.016472 +60 and volts/.01642 +30
    HpTuner log values are 30 to 50 degrees high compared to the actual guage.
    Help!
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Here's the math. Y = mx + b
    Slope (m)
    (310 - 60) / (4.64 - .522) --> 60.709 that's your slope (m)
    Intercept (b)
    y=mx+b
    60 = 60.709 * .522 + b
    b = 28.31
    Put it all together:
    y = 60.709 * x + 28.31
    Test:
    60.709 * 0.522 + 28.31 = 60
    60.709 * 4.64 + 28.31 = 309.9
    So, then you have to invert m to be in the right format for HPT
    That will leave you with
    y = x / 0.016472 + 28.31
    So, looks like something else is going on then if you're already trying basically these formulas. Probably voltage offset issue or something like that
    Instead of transforming the input, if you can get Voltage values at a few different temps then you can make a more accurate formula with that data vs. this one.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    This is the list from 2.24
    This is the 3.xx channel cfg with the transform
    2007Z06#10TRACK.Channels.xml
    Log file
    07 Z06 Log_NW102+_Katech-V6.6_VE5.1_LS9in_OL_TRACK_9-5-16.hpl
