I'm working on a 08 GMC V-Maxx truck what he had a DoD delete "kit" put on then it was bought to me to do the dod delete tune. I cant for the life of me get this truck to start and idle right. I've tried about all I know how to do and it still takes some throttle input to get the truck to start. once it starts it seems to run ok but if you give it a heavy rev it will die. with a light rev the rpm will fall pretty low but it will catch itself and jump back up to a normal idle. It has a small cam in it but other then the DoD and AMF delete its all stock. The cam thats in it is a comp cams part number 146-426-11 specs are dur: 222 int/234 exh, lift: .566 int/.576 exh with a 113 LSA
The dd delete came with a LS2 valley plate with the built in PCV valve that is plugged off. Should I plug off the stock PCV valve in the driver side valve cover and use the one in the valley plate?
here is a log file and the current tune that's in the truck. did I miss something?
