Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: 6.0l 80lb seimen deka injectors 76mm turbo
    Tuner in Training chunkypunky45's Avatar
    Sep 2016
    24
    I have perfect idle and drive perfect down low brakes up a little while hitting boost and in boost then after hitting boost afr gauge and idle fluctuates I have a base tune in it and set up speed density 2 bar also set up ve tables this is the only problems its having and seems that I cant get them to go away
    Aug 2011
    18
    post your tune file and a log would help
    Sep 2016
    24
    s10 basetune
    my base tune
    Sep 2016
    24
    let me know what anyone can find wrong I'm new to this
    13,565
    Are you running a MAF with this setup or going straight speed density?
    I'd go maf-less with this turbo setup for sure.
    You do not have the correct settings for a 2 bar MAP sensor, which you need for running boost. Do you have a 2 bar map??
    Your PE settings need work for boost. You still have a 5,000rpm delay with a 60 second time delay to enter PE, so it could very well be going lean on you and breaking up along with the MAP issue. Lower the rpm delay to 1,500 or around that, set the time delay to 0 seconds. Set your enichment ramp in rate to 4 to bring in fuel as fast as possible under boost. Lower your PE throttle enable to 70% instead of 90%. Set your boost enrichment to match your EQ ratio (Gas). I'd try for 11.5 afr to play it safe.
    Sep 2016
    24
    I have 2 bar map sensor but when I go to I'd nothing comes up but when I go to my vehicle into it says pcm tune is set for 2 bar speed density
    Sep 2016
    24
    And no I'm not running a maf
    13,565
    Okay if no maf sensor, then you must set the MAF fail high to 0hz under the engine diag, then you need to set all 3 MAF DTC's to fail on first error. That way it fails the maf straight away and drops into SD.
    Make sure you are running a seperate IAT because you removed the MAF sensor.
    Under Engine > Airflow > MAP, you need to plug in the correct linear and offset settings for a 2 bar map sensor.
    Sep 2016
    24
    Ok I will look into it and get back to you asap
    Sep 2016
    24
    When I open my tune I can't get os to show anything
    13,565
    Because it's already a 2 bar OS, thus it becomes blank when already upgraded.
    Edit > calibration details > controllers, that shows it's a 2 bar speed density tune.
    Just because it says that does not mean it's anywhere near setup to run speed density, this just allows you to use speed density better, like with the extended VE table and boost enrichment settings for example.
    You still have to change everything else to run in speed density like I was explaining above. MAF sensors and MAP sensor settings still must be adjusted for the changes you wish to do.
    Sep 2016
    24
    oh ok I got what your saying I'm in front of my computer now so ill take a look
    Sep 2016
    24
    I updated everything except the linear setting for map sensor and offset and setting my boost enrich to match my Eg ratio (Gas)
    13,565
    What MAP sensor are you running?
    Are you using a cobalt 2 bar map??
    You still have to change those settings before you start doing any tuning. The cobalt map sensor settings should be 200kpa and 10.33 if I remember right.
    Sep 2016
    24
    s10 edit tune
    edited tune so far does it seem I did everything correctly
    Sep 2016
    24
    acd#213-1631
    gm#12615136
    Sep 2016
    24
    200kpa on map sensor linear tab and 10.33 on offset
    Sep 2016
    24
    I just matched the settings for boost enrich to match my egr ratio (gas)
    Sep 2016
    24
    tried starting it wont idle just dies
    Sep 2016
    24
    I no what the problem is I have no iat sensor
