VCM scanner does not display TPS %
Other parameters appear as normal.
WHat is possible cause and remedy ?
Tried on 2 different vehicles:
2002 Tahoe cable throttle, and 2004 tahoe DBW throttle
I would remove the TPS channel you have in there on the main channel display, then find the TPS (sae) channel again and select it. Clear the last vehicle used in the scanner and have it re-poll for the vehicle you want and see what happens.
