I'm having a bit of a difficult time dialing in my MAF in the light throttle region (for reference...see my signature below for my set-up). At idle...it sits around 1600 hz. At cruise...it sits around 3000 hz. Its the 2000-3000 hz range that is giving me a tough time. When on deceleration, the wideband is showing very fat in this area. When trying a very light acceleration sweep, it showing very lean in this area (5%-20% lean).
Any tips on what I might be doing here? I'm thinking maybe I should ignore the deceleration fatness and simply tune using a very light acceleration sweep? Or is this typical of MAF tuning for this light throttle area and I should ignore it?
Do I need to remove my VE air PID to log MAF correctly? I know that the MAF air PID needs to be gone to do VE properly...wondering if its the same way vice versa.
Any tips would be much appreciated here....
