So, this is my first true foray into tuning and I am trying my best to listen to advice from the more experienced...I have The Tuning School Manual as well as the Lasota Racing Ultimate Guide to GM EFI Tuning for HP Tuners. I am tuning a 2006 Silverado 6.0L w/ a Cold Air intake and Magnaflow 3" Exhaust. The motor has recently been completely rebuilt and I am running a P59 ECM 1 Bar OS.....I set up my tune for VE only, make my runs and log the data...Cut Copy Paste Special by % then 1/2 %...and I get all zeros in my VE LTFT log.... SO, I set my ECM to MAF only for Low-Partial throttle....Make my runs, log my data....Cut, Copy, Paste Special by % then by 1/2 %..... Write and log some more...SO WHY in the name of "ODIN'S ASS" does my MAF look like the mountains of Valhalla and AFR's logged on a WEGO IV W/B are consistently off by 1-2% and sometime upwards of 7-8% on either side... I only run 93 Octane and have stoich set at 14.08 for E10 (which is the only fuel you can buy in NY...This was as per the Lasota Manual that I changed this...Page (9 and 22)... And smoothing just seems to throw everything off again on the next run...so I seem to be chasing my tail. I dropped 1-2 deg of spark across the board in the mid and WOT ranges to eliminate some KR I was getting in those ranges...which eliminated the Knock.... and yet I still can' seem to get my AFR's close to commanded Stoich AFR....
Any help would be appreciated...
Attachment 62559
VE Final Run.hpl
MAF Run 1.hpl
Maf Run 3.hpl
