I can connect to vehicle in scanner. When I go to editor, all I can do is write, not read. So, I wrote. Truck turns over and wont start now.
What did you write to it? Did you disconnect scanner before trying to read and write. There are two images of a vehicle at the top in scanner software, one is connect the other disconnect.
Need more information, this isn't enough to go on.
What vehicle? Was it already licensed?
What file did you write?
In order to read you have to close the tune file....
I think I figured it out. Thanks.
