I just recently installed new injectors, fuel pump and intake on my truck. The pump is a walbro 450, the injectors are bosch 105lb, the intake is a holley hi ram, base pressure has been set at 55PSI. I rescaled the IFR table to match the new injectors, what all else has to be done so the truck will at least idle so I can log it and make adjustments? I have been following the books from the tuning school step by step but when I try to start the truck it starts and dies instantly. I played with the IFR settings and moved the entire table to 35, the truck fires up and runs longer but dies. Using the IFR scaling available on LS1tuningguide I input all those values in the IFR. starts at 118.0 and ends at 129.9. Sorry for seeming like such a rookie(I am) and I need to figure out how to get the truck to idle so I can mess with it more.
Thanks,
John
