I have a 05 Silverado p59 pcm I think, 3 bar os, my problem is when calculated airmass get to 2.32 it goes into reduced engine power, so after reading into some of the stickeys, I scaled back my injector flow rate and in turn the ve numbers got smaller, so I'm making progress. but at 18 psi around 225 kpa ive scaled it back so much my IFR is 54 lbs . I have 127 lb injectors. I'm having trouble at idle, it has to idle 1000-1200 rpm. any way is there a better way to get calculated airmass down. ill post the file. any advice is greatly appreciated
