Another torque source question!
I am seeing oscillation as torque source on my 2017 GT. The problem I am having is I cannot get more than 15 degrees of timing in first gear. What am I missing?
Put the shuffle switch to Disabled to turn off the Oscillation. Don't know what it does, seems to be some kind of traction / torque control
I'd be interested in a log and seeing your tune as well. I've been working on my 2016 as well. Haven't had to many chances to do some WOT 1st gear pulls but was getting oscillation in 3rd and 4th. I tried to disable shuffle switch but was getting some knock below 3500 for some reason but no oscillation up top. You are able to set a rpm to have it disabled so my switch is enabled but have the disable rpm set at 4,000.
