Hi.
This is my first post and the first car I`ve tuned so please bear With me.
The car is running fine as far as I can see. According to my WB my VE should be close. The car has just been tuned on the road With the scanner and never dyno tuned.
I know there should be some timing left in it but I don`t want to push my luck without knowing my base data is ok.
The problem started when I installed the injectors and copied in the data attached from FIC. The car would not start and there was allot of fuel in the oil.
According to FIC the injectors are 42lb at 3 bar but the data should be 58psi. The end result was that I calculated the % increase over Stock injectors and ended up With the data in my tune. The car started right up after this. I`m hoping someone With more experience than me can have a look
Engine info.
GM LS1 Long Block.
GM hot cam. lite ported 799 heads. 11.0 cr.
Fast 92mm intake W/NWP 92mm TB.
FIC 42lb injectors.
1bar SD OS
