at the end of this log, pedal position goes to 99.6%, but tps drags behind.....tune is rich, demand torque is high, 4 degrees of retard in places
what is holding tps back...I've had them match before ??
tune is open loop maf failed, no stft
thx
thx
2003 MY Z06 3.3 liter whipple ...sold at around 1000 rwhp
wip 2015 Silverado w/2.9 Whipple (phase 1 completed) phase 2 in the works
I am wondering if it is because I'm in total open loop mode??
Not open loop but speed density (maf failed). Set your pressure ratio error limit under electronic throttle to 1.9 or so, and try again. What year is the ecm?
It's a 2015 Silverado. So, I should be in closed loop , but with maf failed? at the moment I am in open loop stft disabled, Maf failed
There are 2 ...MaxPRatio fault A and fault B. both are et to .9000. values are 0 to 1.000 I can change, but get warning message...and which do I change?
thx
Maf failed is speed density. The error caused by the maf failure is limiting your pr by way of throttle.
Open loop is no issue, I run my 16 Z06 full time open loop.
Set MaxPR A and B both to 1.9 and override warning.
There is also a place in TM tab to raise Max Pedal for Torque Model or something like that.
you don't have it in your tune. I am not sure you need it anyways, just try with raising PR Max w/Fault first.
will do.....but why don't I have it?....curious
God these cars fucking suck...... Keeping the throttle open sucks on these.... nothing like LTX stuff
